2000 energy kinetics furnace reset after in lockdown
Reever
Member Posts: 1
in Oil Heating
2000 energy kinetics furnace, i have a furnace thats lockdown because of pushing the restart/ reset button to many times what are the steps to get the furnace out of lockdown
@Reever , a burner lockout occurs to prevent dangerous conditions from excessive restarts and saturation of oil in a boiler or furnace. They can also occur if you are out of oil. Before resetting the primary control, the issue should be diagnosed so a larger problem does not occur. If you do not feel confident in your ability to do that, you may wish to call a competent heating professional to make sure that everything is working properly. Please PM me or call 908 735-2066 if you’d like assistance in finding the support you need.Thank you,
RogerPresident
Energy Kinetics, Inc.0 -
- 116 Geothermal
- 169 Indoor-Air Quality
