1-pipe steam TRV question
TommyMeBoy
Member Posts: 5
I just installed 2 Danfoss TRV's (the ones everyone recommends) on radiators in rooms that really overheat and have a question. I understand the principle of the TRV that it will close when it reaches the desired temp setting but I was wondering if I should set the dial for a bit less then I want since the radiator is hot and will continue to heat for a bit? We only started the system yesterday and I'm wondering what I can expect and if the radiator will start to cool even though the system is running to produce heat in other areas?
Leave it for now. Let the heating season start...You'll know instinctively what to do mad Dog 🐕0
- 50 Industry Classes
