Diy HVAC Project
brian085
Member Posts: 3
Just wanted to share a project of mine that’s starting to come together. Removed single stage ac/furnace and installed variable speed heat pump with two stage gas furnace. Replaced ductwork and zoned unit. Upgraded filter set up and installed a steam humidifier. Combi gas boiler for radiant that’s in progress. Some rough in for future zones as well. Some touch ups left but what’s a project without having something still needed to be done?
2
Very nice work,it should be a comfortable homeBob "hot rod" Rohr
Your hired!0
Thanks guys! Second manifold going in. The 8 boxes of pex in the background is daunting.0
Get a good uncoilerBob "hot rod" Rohr
- 110 Chimneys & Flues
- 983 Plumbing
- 387 Solar
