Motorized valve not opening (normally closed valve) even with a new motor valve
westviewveg
Member Posts: 1
Hello, my new motor valve opens manually before connecting to the wires but once connected it wont open manually not auto. I thought the old motor valve was the culprit but with new motor valve it does the same thing. local plumbers cant figure out what the issue it. What could be the issue here? Another motor valve opens ok manually but not opening on auto. Could this be the wire/electric cord issues?
What's the voltage at the zone valve?0
post pictures of both valves showing the manual lever, and any labels, both valves,
also show the flow direction indicator, if there,
and indicate your direction of flow,
maybe your wired for normally open valving(?)HVACNUT said:What's the voltage at the zone valve?
post a distant shot of boiler, valves, and zone controller(if applicable), all in one or 2 shots,
known to beat dead horses0
