Slab Sensor Thermostat Recommendations
Chevra
Member Posts: 11
Running a Navien condensing boiler for the heated floor in my shop. Single zone and currently using air temp thermostat control. I would like to switch to a thermostat that can control by slab temp and air temp. It felt like on certain days when it was warm outside the slab would cool down to much, then the boiler runs way more to catch up once the sun goes down.
What are some recommended thermostats to go with? I don't want anything fancy, nothing programmable or anything of that sort. Basic but reliable. Let me know!
Tekmar T stat with 071 Slab Sensor. They have several models I believe. Go on the website or call their Tech Support or Call James Rathe at Rathe Associates if you are on Long Island 🏝, he'll guide you. Tekmar is the Best bet. Mad Dog 🐕1
Another option is the HBX THM-0100. Comes with a 10’ stainless steel sensor. Easy programming for air, floor and air/floor operation. Other models available including wireless communicating thermostats. In NY/NJ contact Advanced Technology Sales & Consulting for where to purchase and technical support.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
