Condensing water heater
kobuck
kobuck Member Posts: 3
I’m trying to understand when the water heater is in ideal condensing operation.
When I turn on the water slow, the blower fan is near silent. Increase the faucet draw and the fan speed will change to a higher speed. Is it more efficient with blower barely running or running fast?
Thanks!
MDL
    pecmsg Member Posts: 7,043
    Make and model?
  • kobuck
    Takagi T-H3M-DV-P
    Thanks!
    hot_rod Member Posts: 27,416
    It is most efficient when it is not running😗
    Next would be when it is condensing, supplying low flow at lowest useable temperature.
    Think of a vehicle, faster speeds, more stop and go uses more fuel.
  • Intplm.
    Intplm. Member Posts: 3,005
    Thanks!
    MDL
    "Is it more efficient"?
    That depends on the design. And the environment they are installed in.
    These water heaters have four or even five choices or modes of operation.
    The modes are almost always posted with an explanation of what they do for efficiency or the best mode of use for your needs. You can select the modes right from/on the water heater.
    For example: Full hybrid selected would be great when installed in a garage in Florida taking advantage of the surrounding heat to heat the water.
    A cold location mode may best be used in the state of Main, using a combined mode of surrounding heat and electric elements.
    The mode that the water heater is in and the water heater's surroundings will dictate the condensing.
    Larry Weingarten
  • kobuck
    Intplm, my water heater only allows for temperature adjustments. It’s a basic tankless water heater.
    I guess I’m trying to understand why the blower speed increases with water demand and does it condense better at low or high blower speed.
    Thanks for explanations. Just interested in learning how it works!
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,088
    Hi, Just guessing, but if the burner is not just on or off, and can modulate, than the fan could be adjusting speed to match burner output. Bigger flame needs more venting.
    Yours, Larry
  • Intplm.
    @kobuck. Maybe send some pictures and post them here. We can get a better idea of what you have.
