New to an old home... Steam radiator help
ankman81
Member Posts: 3
Hello all,
We moved to an older home that has steam radiators with a single pipe system. One of the radiators in the bathroom blows out steam at the part in the attached picture. There is no other vent. I tried to screw this tighter, but it still blew out steam. There is no control valve at the inlet to turn this radiator off completely
Appreciate your help in advance!
Wrong type of valve. You want a steam radiator vent, that is an automatic air vent for a hot water system although i think it says steam in some catalogs but it is really a hot water vent. Get a straight steam vent for it, probably a rather slow one because that fin tube is less likely to have an issue on steam if the vent is slow. the right kind of vent looks like a little can with threads on the bottom.
You can replace it with a plug from the hardware store until you can get the right vent.0 -
YAY!!!!!!!!!!!!!!!!!0
