New to an old home... Steam radiator help
Hello all,
We moved to an older home that has steam radiators with a single pipe system. One of the radiators in the bathroom blows out steam at the part in the attached picture. There is no other vent. I tried to screw this tighter, but it still blew out steam. There is no control valve at the inlet to turn this radiator off completely
Appreciate your help in advance!
    mattmia2 Member Posts: 17,206
    edited October 2023
    Wrong type of valve. You want a steam radiator vent, that is an automatic air vent for a hot water system although i think it says steam in some catalogs but it is really a hot water vent. Get a straight steam vent for it, probably a rather slow one because that fin tube is less likely to have an issue on steam if the vent is slow. the right kind of vent looks like a little can with threads on the bottom.
    You can replace it with a plug from the hardware store until you can get the right vent.
    EBEBRATT-Ed Member Posts: 20,394
    Are you sure your system is steam? That is a hot water air vent with fin tube baseboard with copper pipe going to it. Looks more like a hot water job than a steam job from what that picture shows.
    Intplm.
  • ankman81
    ankman81 Member Posts: 3
    Hi, thanks for your help. The whole house is a steam set up -- all the other radiators in the house are the regular cast iron type. This is the only small fin set up in a bathroom. I was able to find a vertical steam vent (maid o mist) at the local hardware store and it did the trick. Thank you!
  • leonz
    leonz Member Posts: 1,849
    YAY!!!!!!!!!!!!!!!!!
