Baseboard Heater Not Heating
jgk381
Member Posts: 4
Hi, my baseboard heater isn't heating and thought maybe someone here could give me some advice.
When I turn the termostat on, there is a metal disk in the motor (under the cover) that spins really fast for 3-5 seconds, then stops and nothing happens after (no heat).
When I turn the thermostat off, that disk spins again for 3-5 seconds and then stops.
I assume that the disk spinning indicates that it's getting power, so what else could be preventing it from generating heat?
Got a picture? It sounds like a motor operated zone valve.Bob "hot rod" Rohr
Yes it's one of these Honeywell zone valves:
I'll try to post a picture of my actual unit later, but it's the same model as the one linked above.
Bad end switch in the zone valve. Replace the zone valve.0
I would verify that the circulator is running, and the zone is not airbound before throwing parts at it.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
