Part identification help!
evanczekuc
Member Posts: 3
Can someone tell me what this is? I'm thinking it's a old flow check but I'm not sure
How is it piped into the system?All Steamed Up, Inc.
Consulting0 -
Post a shot from further away.0
I added another picture. There is one on each zone.0
Is there a screw slot or a hex on the end? Looks like an old style isolation or balancing valve.0
There's a hex on top AND on the side.0
evanczekuc said:I added another picture. There is one on each zone.
One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0 -
one on each zone? are they circulator zones? then they are flo-check valves if there are no other anywhere else on the loop (zone). otherwise the zone that is not calling will have water moving backwards depending on the amount of resistance that loop has compared to the path thru the boiler.
looks a lot like this thing.Edward Young Retired
If it has an arrow on it, it is a check valve.
Rick0 -
I agree with @rick in Alaska
Looks like a check , could be a flow check. For me the pipe hole with a plug in it that is on a 45 gives it away.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
