Part identification help!
evanczekuc
evanczekuc Member Posts: 3
edited October 2023 in Radiant Heating
Can someone tell me what this is? I'm thinking it's a old flow check but I'm not sure
    Steamhead Member Posts: 18,395
    How is it piped into the system?
    Consulting
    pecmsg Member Posts: 7,020
    Post a shot from further away.
  • ScottSecor
    ScottSecor Member Posts: 1,031
    Maybe use the flash on your phone or camera?
    mattmia2 Member Posts: 16,432
    And with light and in focus.
  • evanczekuc
    I added another picture. There is one on each zone.
    Is there a screw slot or a hex on the end? Looks like an old style isolation or balancing valve.
  • evanczekuc
    There's a hex on top AND on the side.
  • reggi
    reggi Member Posts: 537
    The second unit looks like perhaps it was overtightened and the body cracked. . Though neither one really appears to be something serviced until there's a problem.,. So are you having a problem?
    One way to get familiar something you know nothing about is to ask a really smart person a really stupid question
    EdTheHeaterMan Member Posts: 12,023
    one on each zone? are they circulator zones? then they are flo-check valves if there are no other anywhere else on the loop (zone). otherwise the zone that is not calling will have water moving backwards depending on the amount of resistance that loop has compared to the path thru the boiler.
    looks a lot like this thing.
  • rick in Alaska
    rick in Alaska Member Posts: 1,523
    If it has an arrow on it, it is a check valve.
    Rick
    EBEBRATT-Ed Member Posts: 20,074
    I agree with @rick in Alaska
    Looks like a check , could be a flow check. For me the pipe hole with a plug in it that is on a 45 gives it away.
