Boiler drain valve seized
So here it goes... I have an Ek1 that has a drain cock that I put a wrench to it to remove and it just wouldn't budge. I need to change it because it leaks at the T-handle when it is in the open position. I believe they just used Teflon tape on the threads. (I was able to replace the other drain cock and upon removal I could see the old tape on it)
I was thinking to use a blow torch but am concerned about causing damage to any surrounding parts or something happening to the piping. And I'm worried about putting more muscle into the wrench and not breaking something that way too.
Any pointers here on a tried and true method would be appreciated, thank you.
EDIT: I considered possibly using an air ratchet to get that "hammer" effect. But then noticed the β rim of the valve is bigger diameter than the nut , so I wouldn't be able to get a socket tight on it unless I cut the valve.
If you had a Ferrari, Rolls Royce, or new Cadillac would you attempt to work on it yourself? I'm all for DIY but Energy Kinetics is not a good DIY boiler. For one thing, their parts are ONLY available to a select group of their dealers. I can't buy their parts, you can't buy their parts, Joe Plumber can't buy their parts, many very good Hydronic heat men, can't buy their parts.
That's a very well made (and expensive) boiler, but it needs annual service from an EK dealer. You need to establish a relationship with an EK dealer.
http://alloy-artifacts.org/proto-empire.html#tubing-also-tac
This on the valve and a ViseGrip 10C on the goesinto for backup might work. A second ViseGrip 10C could substitute for the fancypants TAC socket. No blowtorch.
An EK dealer could do all the other important things like properly clean the high drama heat exchanger. Well worth it to keep that boiler in top notch condition.
I like vise grips because you can wiggle the nut or fitting in both directions. To avoid breaking fittings or bolts, the secret to success is to work it loose. Back and forth to break the corrosion and establish movement. Pipe wrenches are not so great for back and forth. Ratchets and the fancy pants TAC crowfoot socket are also one direction only. Breaker bar better than ratchet for wiggling back and forth.
Heat from a Mapp Gas or Acetylene torch can help, but you have to protect adjacent items.
Thank you for the tip. The boiler is maintained yearly by a local dealer. Boiler drain valves however are readily available just about anywhere there's a plumbing supply shop (Home Depot, Grainger, etc). So this is not a manufacturer / dealer specific part.WMno57 said:If you had a Ferrari, Rolls Royce, or new Cadillac would you attempt to work on it yourself? I'm all for DIY but Energy Kinetics is not a good DIY boiler. For one thing, their parts are ONLY available to a select group of their dealers. I can't buy their parts, you can't buy their parts, Joe Plumber can't buy their parts, many very good Hydronic heat men, can't buy their parts.
But since you brought this up, I ended up discovering some parts can be ordered by the dealer and installed by the customer. (For example I will be replacing the front cover and insulation board). And I already replaced one of the taco auto air vents myself (bought on Amazon). But that's off topic anyway.
Regarding your other replies... I'll give it a go with the vice grips. I also sprayed some penetrator and letting that work itself in before I take another swing at this.
Again thank you and I appreciate your help !
**On another note, that ball valve is two sections that can be unscrewed. So if I can find this same one I can just replace the bottom (ball valve) section in quick minute.
Doesn't take a screwdriver πͺ to hammer π¨ that nail π1 -
For round things, the ViseGrip 10C is better than the ViseGrip 10W.
Yes I tried with a crescent. But thank you for the pipe wrench tip. Will try that if the vice grips don't do it alone.dko said:I don't see any bite marks, what are you using? I understand if you are just using a crescent wrench on the drain valve, but you should be holding back with an appropriately sized pipe wrench on the tee. Then feel free to use much more leverage on the drain valve.
Doesn't take a screwdriver πͺ to hammer π¨ that nail π0 -
@Demon
You just need bigger wrenches=more leverage.
Put a wrench above the valve as a back up. It's easier to pull when you have something to pull against. 14" pipe wrenches will do it, maybe an 18". You can buy some cheap ones at Harbor Freight. You can also put pipe over the wrench handles for more leverage. It will come out2 -
these 1/4 turn hose bibbs use an o-ring on the stem. but it is not accessible. not a rebuildable valve.
If you had the ability to unscrew the two sections of the valve, you could unscrew the valve from the fitting much more easily.Demon said:
I can put the leverage I'm just worried smth unintended might break lol, so I've been holding back. Just trying this slowly. Got all the tools just need to muster the courage haha.EBEBRATT-Ed said:@Demon
From what I see you guys saying is that T and can handle a lot of force and I shouldn't worry about putting some elbow grease into removing the valve πͺDoesn't take a screwdriver πͺ to hammer π¨ that nail π0 -
Yes, yes I would. Probably more so than I would a Kia.
I've yet to find a part I can't get one way or another.
What's wrong with ball valves?WMno57 said:A short lived ball valve. How could that possibly happen? The HeatingHelpers all love ball valves. Ball valves are the greatest thing since sliced bread!
@WMno57 For what its worth, any heating professional can buy parts or get tech support if needed from Energy Kinetics, you do not even need to have an account setup to do so. You only need to be a dealer to buy boilers for install.
Joe Szwed
Energy KineticsJoe Szwed
Energy Kinetics2 -
Long story short ... The valve snapped off π... The threading is seized solid inside the pipe. Got a plumber coming ... So much for DIY.Doesn't take a screwdriver πͺ to hammer π¨ that nail π0
i would have suggested the slices of pie method0
or an inside pipe wrench0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
