Boiler Conditioner
MatthewKlein
Member Posts: 13
Hello,
I have an older cast iron boiler that will require draining for maintenance. Is there a product that should be added to the system before refilling the water?
Thanks, Matthew
Thanks, Matthew
I like Rectorseal 8-way boiler treatment. You can usually find it or a similar product at your local supply house, or you can order online.
https://www.supplyhouse.com/Rectorseal-68712-8-Way-Boiler-Water-Treatment
Thank you0
This is a hot water boiler, not steam. Do I leave this product in permanently? or is it a flush0
I would run a cleanser first, followed by good water and a conditioner.
These aerosol kits make it easy. Squirt it into a hose connection to the system.Bob "hot rod" Rohr
Living the hydronic dream1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
