Retrofit oil valve with biodiesel compatibility
dh1989
dh1989 Member Posts: 22
Is there a preferred oil valve for use with the Suntec A2VA-7116B pump? I was trying to find one that was listed as biodiesel blend compatible, to future proof as RI is supposedly going to a B15 blend by 2025. I've had a hard time finding anything bio rated on the market. My pump doesn't have a valve right now but I upgraded to a Genisys control which supports the pre-purge delay.
Thanks.
    EBEBRATT-Ed Member Posts: 20,185
    What type of valve are you looking for/ A firomatic valve or a solenoid valve
  • dh1989
    Sorry, was referring to a solenoid valve.
  • STEVEusaPA
    Most standard fuel pumps are fine up to B20.
    More important is that the strainer gasket and fuel filter gaskets are rated for bio.
