Retrofit oil valve with biodiesel compatibility
dh1989
Member Posts: 22
in Oil Heating
Is there a preferred oil valve for use with the Suntec A2VA-7116B pump? I was trying to find one that was listed as biodiesel blend compatible, to future proof as RI is supposedly going to a B15 blend by 2025. I've had a hard time finding anything bio rated on the market. My pump doesn't have a valve right now but I upgraded to a Genisys control which supports the pre-purge delay.
Thanks.
Thanks.
What type of valve are you looking for/ A firomatic valve or a solenoid valve0
Sorry, was referring to a solenoid valve.0
Most standard fuel pumps are fine up to B20.
More important is that the strainer gasket and fuel filter gaskets are rated for bio.There was an error rendering this rich post.
