Leaking shutoff valve
Is it worth switching to a ball valve or should I repair the packing?
Thanks!
You should not need to turn it very much... Maybe 1/4 turn is all you should need. Don't over do it, because it looks old and you do not want to crack the nut. Then you will need to call a plumber for the larger leak you create
Just clean up the stem with some scotchbrite if it is crusty and put a little string packing in it.0
I can't tell if that is a gate valve or globe valve. If it is a globe valve it is fairly restrictive and might be worth replacing. You'd drain the tank until the water was below the valve then replace it.0
It is a stop and waste valve @mattmia2 like this onemattmia2 said:I can't tell if that is a gate valve or globe valve. If it is a globe valve it is fairly restrictive and might be worth replacing. You'd drain the tank until the water was below the valve then replace it.
https://www.supplyhouse.com/Matco-Norca-202C04LF-3-4-Solder-Ends-Stop-Waste-Valve-Lead-FreeEdward Young Retired
That doesn't answer if it is globe or gate. I think it is globe especially since the waste is where a gate would seal off. Oddly the supplyhouse.com listing doesn't mention if it is a globe or gate valve or show a picture of the end either. Both globe and gate valve are available with waste.EdTheHeaterMan said:
https://www.supplyhouse.com/Matco-Norca-202C04LF-3-4-Solder-Ends-Stop-Waste-Valve-Lead-Free0 -
It is not a Gate Valve. I thought that everyone knows that a Stop and waste valve is a type of globe valve. And I'm not even a plumber
And regardless of the Gate or Globe ...the fix is the same on both. Tighten the packing nut
It is purely by convention that one would know it is a globe valve., You can get sink stops with ball valves.0
It's a globe valve.
@oldcastiron
shut the water off on the street side of the valve. Take the valve handle off and clean up the valve stem Loosen the packing nut and take some string packing or Teflon tape twisted into a string and wrap some around the stem. A little silicone grease on the threads. Then snug it up and turn the water on and check for leaks. If it drips snug it a little more.0 -
Gate would've never crossed my mind looking at that.
I like Ed's and @EBEBRATT-Ed 's advice.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@EBEBRATT-Ed has good advise for a valve that is opened and closed on a regular basis.
But the fast fix is to tighten the packing nut for now. You can get to the more involved maintenance when you have more timeEdward Young Retired
This has worked for me:
- Clean deposits off stem with small wire brush
- LOOSEN packing nut
- Barely tighten packing nut
- Turn stem in and out
- Tighten packing nut until dripping stops (or before if you are about to strip the threads)
Step 2 is important for success.0 - Clean deposits off stem with small wire brush
- 117 Geothermal
