Air to Water Arotherm Plus problem
Experts,
Can Arotherm plus air to water heat pump work in parallel: heat up water cylinder (DHW) and UFH same time? forget about efficiency here, just a parallel operation? how to achieve this?
thanks
  • kcopp
    kcopp Member Posts: 4,678
    I dont think the tank can produce enough recovery heat to heat an area...unless its a very small area.
    Most of the energy production will be from the electric resistance.
