Air to Water Arotherm Plus problem
vlp2024
Member Posts: 1
Experts,
Can Arotherm plus air to water heat pump work in parallel: heat up water cylinder (DHW) and UFH same time? forget about efficiency here, just a parallel operation? how to achieve this?
thanks
thanks
I dont think the tank can produce enough recovery heat to heat an area...unless its a very small area.
Most of the energy production will be from the electric resistance.
- 129 Chimneys & Flues
- 122 Geothermal
