Buderus Logamatic meaning of MIH temperature
harried
Member Posts: 10
in Oil Heating
Scrolling through the 2107 control panel shows MIH temperature.
What is that?
What is that?
Google the manual
Read it top to bottom- not in there0
What menu are you scrolling thru? I have not seen that one before?
The main simple one - blr temp, dhw temp, run time etc0
House has large area of radiant floor - suspect it has something to do with motorized mixing valve.0
Yeah...dont recall seeing that...Please post a picture of the actual display. Mad Dog 🐕
How do you post a picture?0
Technopeasant but think I figured it out
Replaced the Firomatic knob - threads had a little creep - that’s the old one on top0
Given the recommended water temperature for radiant heat beneath an oak floor (85 -100 Fahrenheit) suspect this setting has something to do with the variable motorized tempering valve for the radiant loop.
Still curious what MIH stands for.0 -
Thanks - correct - it’s the water temperature out of the tempering valve for the hardwood floor radiant section
Putting a little heat to the sensor strapped to the output nipple confirmed it0
