Buderus Logamatic meaning of MIH temperature
harried
harried Member Posts: 10
Scrolling through the 2107 control panel shows MIH temperature.
What is that?
  • STEVEusaPA
    Google the manual
  • harried
    Read it top to bottom- not in there
    EdTheHeaterMan Member Posts: 12,506
    What menu are you scrolling thru? I have not seen that one before?
  • harried
    The main simple one - blr temp, dhw temp, run time etc
  • harried
    House has large area of radiant floor - suspect it has something to do with motorized mixing valve.
  • STEVEusaPA
    Post a picture of the screen. Are you sure it doesn’t say 'MIX'?
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,680
    Yeah...dont recall seeing that...Please post a picture of the actual display.   Mad Dog 🐕
  • harried
    How do you post a picture?
  • harried
  • harried
    Technopeasant but think I figured it out
  • harried
    Replaced the Firomatic knob - threads had a little creep - that’s the old one on top
  • harried
    Given the recommended water temperature for radiant heat beneath an oak floor (85 -100 Fahrenheit) suspect this setting has something to do with the variable motorized tempering valve for the radiant loop.
    Still curious what MIH stands for.
  • SuperTech
    SuperTech Member Posts: 2,669
    It's mix temperature
    HVACNUTGGross
  • harried
    Thanks - correct - it’s the water temperature out of the tempering valve for the hardwood floor radiant section
    Putting a little heat to the sensor strapped to the output nipple confirmed it
