Point of use Rheem to replace oil boiler for indirect tank domestic water only?
Abi
Member Posts: 2
Is it possible to use point of use .6 GPM tankless on a closed loop combine with HTP 50 gal indirect tank to get hot water for domestic showers and kitchen.
I have 90k btu a burnham boiler that is on last leg though we just replaced indirect tank 1 year before so it’s fairly new. HTP 50 gal. For heat we have 72k btu air sourced heat pump upgrade upcoming. Trying to determine what would be least expensive method to replace oil boiler completely to get hot water. I fall in zone 5 New York State WestChester county.
So is it possible to add Rheem 3.5 kw tankless and route a closed loop water line via tankless that circulates and heat the coil inside HTP tank and HTP aquastat can direct tankless to stay on till tank comes to required temperatures?
I have solar so electric is a better option for me.
Please do let me know is this a good idea or any better suggestions?
1
Um... well... yeah,, it will work -- after a fashion. You will have about a half hour recovery time on the tank using the bigger tankless (3.5 KW). If I were to do this, I would use the aquastat to control the circulating pump -- which you will have to have -- rather than directly control the tankless (they are controlled by flow through the unit not temperature). You will need a fairly high head pump to get the desired flow -- the head loss through a tankless is large.
That said. How many separate bath/kitchen/utility groups do you have? I realise that discarding the nice new indirect sort of hurts, but a much more direct solution would be one or more tankless units directly feeding the various points of use. There would be little or no difference in total energy use, if that is a concern.Br. Jamie, osb
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
