Old gas water heater
TonKa
Member Posts: 111
So this water heater is 20 years old and has never had any maintenance done on it the entire time. (Gotta love NYC water quality.) It doesn't leak and it's still functioning okay. Sure, replace it. However, they're not ready to do it.
The water heater is kettling and has been for some time. Is it tempting fate to flush this dinosaur? Or, just leave it alone?
1
If you open that drain valve it will probably never seal again
I figured that. A cap is simple enough (and cheap). Is flushing it still not a good idea?
Hi, Let your client know that just working on it is a risk. If they approve, check at all fittings and look into the combustion chamber. Look for any dampness. If you see it, time for a new tank. If it's dry, there are two things first. Replace the relief valve and replace the anode... or add one. At this point, you could wait a year and see if the tank survives. If so, now you can mess with sediment. Replace the drain valve with a ball valve. Use a lined steel nipple into the tank. If it has a gas control that you can dial down, do that to reduce the size of the main flame. This slows heat transfer rate and quiets things down.
Yours, Larry1 -
