18148e Aquastat
Stillkickin
Member Posts: 4
Someone posted that they found a cold solder joint on their aquastat. How? Can the PC board be removed from the housing? Sometimes I have to wiggle the vent wire bundle to get the boiler to light off.
Just get a new one, or have your service provider get you a new one and check the safety limits. And/or even upgrade to a Hydrostat and get the benefits of a more advanced control. And with a well change, a low water cut off. .
What if you do something soldering that interferes with the high limit and you end up with a run away boiler?
Commercial/refrigeration techs routinely solder boards. I wouldn't bother on that one.There was an error rendering this rich post.
Thanks Steve. Wise advice.0
You are best off with a new control...
The electronic controls are less expensive that the analog one you have. L7224U is what I recommend, others like the Hydrostat. but I don't like the adjustment dial.
https://www.supplyhouse.com/Resideo-L7224U1002-120-Vac-Oil-Electronic-Aquastat?_br_psugg_q=l7224u1002
https://www.supplyhouse.com/Resideo-L8148E1265-High-Limit-Vertical-Mount-Aquastat-Relay-15-DegreeF-differential?_br_psugg_q=l8148e1265
Both do the same thing.Edward Young Retired
L7224U will not work with a boiler that has a vent damper. On a boiler without a vent damper you will need to install a 24 volt transformer wired to B1 and B2 to make it work with a 24 volt gas valve and ignition system. I did this exact repair on Sunday.EdTheHeaterMan said:The electronic controls are less expensive that the analog one you have. L7224U is what I recommend, others like the Hydrostat. but I don't like the adjustment dial. https://www.supplyhouse.com/Resideo-L7224U1002-120-Vac-Oil-Electronic-Aquastat?_br_psugg_q=l7224u1002 https://www.supplyhouse.com/Resideo-L8148E1265-High-Limit-Vertical-Mount-Aquastat-Relay-15-DegreeF-differential?_br_psugg_q=l8148e1265 Both do the same thing.
Either way, don't buy another L8148E. They always have the same problem you are experiencing. The Hydrostat for gas boilers is your best option.2
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
