Need public input for WH standard
hot_rod
Member Posts: 26,388
@hot_rod , bottom line: what equipment will not be available if this goes into effect?All Steamed Up, Inc.
Consulting0 -
sounds like gas fired will need to be made more efficient to remain an option?Bob "hot rod" Rohr
Wow, that is a lot of charts.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Vent damper operated off a thermopile.0
As they attempt to save us by regulation, they will certainly overlook a simple factor.
That is, higher efficiency WH's will require 120 volts applied.
It was always an advantage, that during a power failure you would still at least have hot water.
For a prolonged power outage, just filling the tub with hot water would pretty well heat that room.0 -
Or you allow the vent damper to be manually opened to operate during a power outage but close when power returns. I didn't get a sense of what they were requiring, if just reducing standby loss with more insulation would get you there.0
...and this is what is good for us wether we like it or not.
"I'm from the Government and I'm here to help."
and my favorite:
Never hear that from someone that is sitting on the roof of their house in a flood.EdTheHeaterMan said:...and this is what is good for us wether we like it or not.
and my favorite:
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
