Need public input for WH standard
hot_rod
hot_rod Member Posts: 27,339
    Steamhead Member Posts: 18,408
    @hot_rod , bottom line: what equipment will not be available if this goes into effect?
    Consulting
    sounds like gas fired will need to be made more efficient to remain an option?
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Wow, that is a lot of charts.
    mattmia2 Member Posts: 16,504
    Vent damper operated off a thermopile.
  • JUGHNE
    JUGHNE Member Posts: 11,548
    As they attempt to save us by regulation, they will certainly overlook a simple factor.
    That is, higher efficiency WH's will require 120 volts applied.
    It was always an advantage, that during a power failure you would still at least have hot water.
    For a prolonged power outage, just filling the tub with hot water would pretty well heat that room.
    edited September 2023
    Or you allow the vent damper to be manually opened to operate during a power outage but close when power returns. I didn't get a sense of what they were requiring, if just reducing standby loss with more insulation would get you there.
    EdTheHeaterMan Member Posts: 12,045
    ...and this is what is good for us wether we like it or not.
    "I'm from the Government and I'm here to help."
    and my favorite:
    Damned if they do and damned if they don’t 😉
    Ask for public and pro input
    Larry Weingarten
    and my favorite:
    Never hear that from someone that is sitting on the roof of their house in a flood.
