If our community has helped you, please consider making a contribution to support this website.  Thanks!
Buderus SSB 160 cleaning?
                    takoateli
                    Member Posts: 41
                                  in Gas Heating
                    We have a customer who has two Buderus SSB 160 gas boilers. I'm going to do a cleaning and service on them today. It looks like after you pull the gas valve/inducer assembly then there is a band at the top of the combustion chamber you can pull to remove the burner.
I can't find any info on servicing that part of the boiler. The Buderus manual doesn't have any details.
Has anyone ever serviced one of those boilers? They're not very common in this area. We service a lot of the GB142-XX boilers.
            "The burner can be accessed by removing the larger four fan motor mounting nuts."
 Do you have this service manual? surprisingly detailed at first glance compared to many other boilers
 https://www.behler-young.com/UserFiles/Resource/BOSUSAINST00129.pdf0
            Yeah, thanks.
 One issue these boilers had is the plastic internal flue pipes had cracked and leaked condensate. That corroded the connections on the flue temp sensors located under the condensate collector on the bottom of the boiler.
 New sensors are reasonably priced but the wiring harness is $900 our cost!0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
