DRAIN VALVE - BURNAM BOILER
rasord99
Member Posts: 1
I just had my boiler serviced today. The drain valve has a very very small drip. The service tech quoted 1000 to replace and 600 for a quick "bandaid." I have been researching and saw drain valves range from 20-50. Is it possible to purchase one of those and replace after draining water? I am very handy and the prices seem absurd for the work that needs done.
1
Don't ever call him again! Cheapest solution for you...
1) Wire brush off that crud.
2) Vaseline on the threads.
3) Hardware store for a Hose Cap with washer. Tighten with fingers as tight as you can. Shouldn't need pliers.
Option two...Drop system and replace yourself .
Mad Dog 🐕1 -
@rasord99
We can't talk prices on this forum. But some companies are giving the whole industry a bad name.2 -
rasord99 said:I just had my boiler serviced today. The drain valve has a very very small drip. The service tech quoted 1000 to replace and 600 for a quick "bandaid." I have been researching and saw drain valves range from 20-50. Is it possible to purchase one of those and replace after draining water? I am very handy and the prices seem absurd for the work that needs done.
For $999, we have a deal. Just joking. Those prices are obscene. Are you sure that you didn't miss a decimal????1 -
