Copper or black iron at relief valve
seized123
seized123 Member Posts: 432
edited September 2023 in Oil Heating
This has been asked before on this site but I couldn’t figure out the best answer.
Putting in new brass relief valve, what of the piping should be black iron and what copper/brass?
The elbow out of the Weil-McLain WGO-3 (oil, hydronic) says “Ward” and I think maybe Ward doesn’t do copper, so I think that’s iron (see photo). The brass valve would go into that - is that okay? On the outlet side (see photo) there’s a 3/4 nipple to an elbow to the obviously copper drop pipe, I don’t know whether the nipple and elbow are iron or copper/brass.
How do you tell whether an old pipe is iron or copper/brass?
I have to buy a new nipple anyway because it broke right off when I tried to wrench it out of the old valve - maybe it was iron into brass and corrosion weakened it?  Should I make the outlet side brass nipple to brass elbow to copper drop pipe? Can I leave the allegedly iron elbow at the boiler to contact the brass valve? What would you do?
  • ChrisJ
    ChrisJ Member Posts: 16,800
    A magnet will tell you, but everything there except the tube in your hand and the male adapter soldered to it, and the pressure relief is steel.
  • seized123
    What I thought. So, switch them to brass or get iron? Iron elbow at boiler okay to go onto brass valve?
  • CTETeach
    CTETeach Member Posts: 18
    In a perfect world the nipple and elbow coming out of the boiler should be brass. The manufacturer uses steel so steel it is. So, we are going from cast iron (boiler) to steel nipple & 90 to brass the pressure relief valve. The most important thing is that the discharge of the pressure relief valve is piped copper or brass to avoid corrosion. Most codes state a non-ferrous discharge pipe must be used.
  • seized123
    @CTETeach got it. I’m not going to worry about the iron elbow to brass valve, I have no choice anyway, and I think I understand that steel/iron to brass is not as bad as to copper.
    Out of the valve it’ll be brass nipple and elbow to the copper pipe. Thanks!
    pecmsg Member Posts: 6,246
    Just replace all the steel piping with brass and forget about it.
    Mad Dog_2
  • seized123
    I will except I think I’ll leave the steel elbow at the boiler so I don’t have to mess with it. And I figure if there will be galvanization let it be between elbow and valve rather than right at the boiler itself, though I don’t know if that’s a removable nipple on the boiler side of the elbow or some integral part of the boiler (if I were a pro like you guys I’d know, but such is the burden of ignorance).
    EdTheHeaterMan Member Posts: 10,680
    So to follow the "perfect world" analogy, should the cast iron boiler also be brass? Or should we just use steel/iron relief valves? Then what would I do with all these copper to male adaptors I have in my shop? I guess we will never see a "perfect world". All you need to do is look at Washington DC and you will know there is no chance for a "perfect world"
    @seized123, your queries never cease to amaze me. I guess I have been in this trade too many years now. I cant remember a time when I didn't know the difference between a copper fitting or pipe and a steel or iron fitting or pipe. I do know that the silver ones are probably Galvanized and the black or rusty ones are Black Iron. But how they make them galvanized and how galvanizing reduces the amount of rust that happens on what seems to be otherwise identical fittings was never explained to me, and I didn't care to know. You see, to know what time it is, I look at a clock, I don't try to build a clock.
    So my question to you is, Why do you need to know?
    Mad Dog_2
    hot_rod Member Posts: 25,272
    Id consider these dry connections, so the blend of dis similar fittings should not cause corrosion or electrolysis
    Tank water heaters always have brass T&P valves into a steel tank, as do boilers
    I don’t recall a code stating non ferrous relief tubes?
    I do recall old codes stating metallic tubes, but I see water heaters with plastic relief tubes now
    Either are fine. I have had both pass inspection.
  • ChrisJ
    The inspector in my area wants copper or brass.
    Is it code?  No.
  • seized123
    Thanks for all the comments.  I put in all brass after the presumably iron elbow out of the boiler, then the old copper relief tube, hope that turns out okay.
