Aftermarket combustion air intake control
jduncan
Member Posts: 6
in Gas Heating
In an idle hot water furnace, it is well understood that the furnace itself presents a serious heat loss. Such is not related to combustion efficiency as the burner is OFF (which is often most of the time) --it draws warm air out of the building, heats it with the largest, hottest convection "radiator" in the system and vents it up the chimney.
My question:
Is there an aftermarket control that turns off the combustion air intake when the furnace is idle? I thought of designing one myself, but would prefer one that is tried and tested.
I first ran across such a system about 60 years ago--it was an oil burner manufactured by Timkin. In today's world, such are standard equipment on many or most new furnaces, but how does one retrofit an old furnace?
My question:
Field Controls, among others -- several models of draught dampers. Quite common. Some of us talk the efficiency gains (minimal) and love them, some of us regard them as a potential single point of failure at oh dark hundred New Year's Eve in a blizzard and hate them.Br. Jamie, osb
- 15.8K Strictly Steam
