Abandoning basement oil tanks
jesmed1
Member Posts: 1,474
We have two fairly new (5 yrs old) 275-gal oil tanks in the basement. We may be switching to gas burners in the boilers, so may be abandoning the oil tanks in place, and I'd like to know what the rules are for that.
I know we'll have to remove the two fill pipes that go through the wall to the outside. We have two jacketed copper feed lines that run inside the concrete floor over to the oil tanks. Can I just leave those feed lines in place and cap them where the would normally connect to the oil burners? There are ball valves at the tank exit, so obviously we'd close those. And I have a compressor, so could blow those lines out first back into the tank if that is advisable.
We have about 330 gallons of oil left in the tank. Ideally we'd try to burn as much of it as possible before switching to gas, but I don't want to wait until we're in the middle of the heating season to make the switch in case anything goes wrong. So it might be preferable if we could offer the oil at a discount to someone with the proper equipment (explosion proof pump, etc) who would be willing to pump it out. Is that possible, or are there rules/regulations against that?
Thanks in advance for any words of wisdom.
In most locations, legally you have to remove the tanks.All Steamed Up, Inc.
Consulting0 -
OK, thanks. I have reviewed my state regs (MA) and they cover underground tanks, but I couldn't find anything about above-ground tanks. I'll call my local building inspector and Fire Dept and see what they say.Steamhead said:In most locations, legally you have to remove the tanks.
@jesmed1
I am in MA. If the tanks are not connected to anything and are not used (abandoned)they must be removed as far as I know.0 -
OK, thanks Ed. A local installer I talked to said he would just remove the fill pipes, but maybe he didn't know the rules. I'll confirm tomorrow with the building inspector/Fire Dept.EBEBRATT-Ed said:@jesmed1
Why would want to leave them in the basement ?
jesmed1 said:
If the local 'installer' doesn't know the rules they shouldn't be doing the job nor should you be hiring them to do work which may wind up being nonconforming with regulations and proper trade practices.EBEBRATT-Ed said:@jesmed1
A local installer I talked to said he would just remove the fill pipes, but maybe he didn't know the rules. I'll confirm tomorrow with the building inspector/Fire Dept.0
- 120 Geothermal
