Can anybody ID this German thermostatic mix valve?
gerritg
Member Posts: 3
Only idenfying mark is an “H” Here are the pics. Installer never adjusted it and I have no info on it and don’t know how to adjust it. Thanks in advance!
Its just a simple Honeywell fill valve . FM911
Thanks! I cannnot find another adj valve anywhere, so I don’t think he put in the right valve or its in the wrong place. It’s for a Triangle Tube Instinct Combi that was installed by a known questionable tech who was fired after our install for theft. Couple more pictures, I welcome feedback from those who work with these for a living, I’m an electronics engineer.
What temperature are you trying to adjust?
I’d doubt a German made valve would use psi instead of bar , and 1/2 instead of mm.
Why do you think it’s German?There was an error rendering this rich post.
I’m not concerned about the fill valve anymore I’m just curious why there’s not a thermostatic mixing valve. Oh, and the fill valve said made in Germany.0
Why do you think that you need a thermostatic mixing valve?0
Can we see a close-up pic of the printing on the red plastic cap?0
https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Resideo Braukmann-VF06-100-SUSUT-Install.pdf
Pretty simple. I have used a number of them.0 -
