Can anybody ID this German thermostatic mix valve?
gerritg
gerritg Member Posts: 3
edited September 2023 in Domestic Hot Water
Only idenfying mark is an “H” Here are the pics. Installer never adjusted it and I have no info on it and don’t know how to adjust it. Thanks in advance!
  • That's a fill valve, not a mix valve.
    "H" = European Honeywell?
    Mad Dog_2HomerJSmith
  • kcopp
    kcopp Member Posts: 4,696
    Its just a simple Honeywell fill valve . FM911
  • gerritg
    Thanks! I cannnot find another adj valve anywhere, so I don’t think he put in the right valve or its in the wrong place. It’s for a Triangle Tube Instinct Combi that was installed by a known questionable tech who was fired after our install for theft. Couple more pictures, I welcome feedback from those who work with these for a living, I’m an electronics engineer.
    hot_rod Member Posts: 27,706
    Looks like someone jammed a press female adapter on the outlet? I think that is a BSP thread.
    HomerJSmith
  • kcopp
    What temperature are you trying to adjust?
  • STEVEusaPA
    I’d doubt a German made valve would use psi instead of bar , and 1/2 instead of mm.
    Why do you think it’s German?
  • HomerJSmith
    HomerJSmith Member Posts: 2,793
    A mixing valve has 3 ports, a fill valve has 2 ports. That's very much like Caleffi's design. Showing the pressure gauge placement.
    Intplm.
  • gerritg
    I’m not concerned about the fill valve anymore I’m just curious why there’s not a thermostatic mixing valve. Oh, and the fill valve said made in Germany.
  • HomerJSmith
    Why do you think that you need a thermostatic mixing valve?
  • psb75
    psb75 Member Posts: 1,148
    Can we see a close-up pic of the printing on the red plastic cap?
    Typically you do not need mixing valve on a combi.  The control should manage the outlet temperature accurately
    There are s few states that require mixing calves on all DHW heaters, Vermont, Maine perhaps
    Intplm.
