Religious Manifold
Member Posts: 4,712
Must be 1940s-50s. They did a lot of it during that time and during WWII fitting were in short supply.0
Mazel tov0
Amen!
Will this get me into trouble?
I like the creativityBob "hot rod" Rohr
I thought it was 8 days, not 9, but i'm no expert.0
Hi, That "Y" at the bottom is interesting too! Wonder if it's homemade? All quite clean. Took some skill!
Yours, Larry0 -
Looks like it was all done with that punch that makes a flange in the side of the tube that you can then braze another tube in to.Larry Weingarten said:Hi, That "Y" at the bottom is interesting too! Wonder if it's homemade? All quite clean. Took some skill!
Yours, Larry0 -
They still do it a lot in Europe, bending and T-Drill manifolds.EBEBRATT-Ed said:Must be 1940s-50s. They did a lot of it during that time and during WWII fitting were in short supply.
Here's a recent one from our friends across the pond:
4 -
It really should be six side branches, which are lit in the evening (one on the first day, two on the second, etc.) and one central flame, which is kept lit. But -- there are other perfectly acceptable traditions and nine branches, rather than seven, is not uncommon.Br. Jamie, osb
Different tradition -- depictions of the Temple menorah are seven. with the always lit centre. The nine branch one is more or less specific to Hannukah.
It gets complicated. That's why you talk to a rabbi...Br. Jamie, osb
- 50 Industry Classes
