Ordered!
SteamtoHotWater
Member Posts: 123
I decided to go ahead and make the primary 1 1/4” because it seemed like the safest thing to do. I’m a little nervous as I haven’t had to sweat pipe in over twenty years. It was a summer job and, as I recall, I kind of sucked at it.
I’ve been pondering this boiler install for a couple of years. I’ve been lurking and reading for about a year. I started seriously researching back in May. Then it took me a good couple of months before my current basic understanding of how involved this little project of mine has become.
I’ve got a couple weeks of demolition ahead of me. And I’m guessing it will take me at least four weeks to install everything. So, right before it gets too cold, after I’ve got everything assembled, expect me back - desperate for advice on how to turn the damned thing on.
I just wanted to especially thank, in no particular order:
hot_rod
Mad Dog_2
GGross
dko
Hot_water_fan
Ironman
And anyone else I may have missed who gave their valuable time to help me out. You people obviously have a passion for what you do. I’d gladly buy you a beer or coffee.
What did it all cost?*
- $8,000
- $10,000
- $12,000
- $14,000
(nevermind)
*(I know prices are verboten, but hopefully this will slide as I’m not soliciting or comparing and they’re just ranges)
1
Thanks, but there are too many regional prices, determined by things none of us can control, which is why this site does not allow discussions about pricing. That is how this site works. Please respect that. It’s not a game.Retired and loving it.0
Soldering tips:
Ream the burr out if you cut the tube with a tubing cutter. A pencil reamer, pocket knife or Unibit in a cordless drill.
Sand the tube, even if it is brand new
Clean the fittings with a fitting brush, even new ones
A light coating of flux on both parts
Heat the tube and fitting evenly all around
Once the solder melts at the joint take the torch away
Solder flux burns, turns black if it is over heated, then you need to clean both pieces and start again
Solder flux burns just above the melt point of soft solder, so it is easy to over heat it
Bridgit solder melts at low temperature and fills loose joints nicely, a good choice for beginners
Tinning flux makes it a lot harder to burn out the flux before the surfaces wet.
Heat from the opposite side where you apply the solder. Put the torch mostly on the heavy part of the joint. the hot part of the flame is at the tip of the inner cone.
Use a vise or pliers or at least gloves if you use a unibit for reaming for short pieces. I had the burr catch on the bit and flip the nipple around and over the tip of my pinky where the burr on the other end made a nice slice in my pinky.0 -
You are going to have a great install! looking forward to the results!0
Wouldn't have to order anything extra..
I would put the drain valve under the boiler instead of a regular ball valve. That way you can easily flush the primary heat exchanger during maintenance.
I don't think you need a drain valve on the left anyway. You have two low point drains (sep4 and expansion tank valve).0 -
Why have you decided to do a mixture of sweat and press?0
Noted. Thanks.dko said:I would put the drain valve under the boiler instead of a regular ball valve. That way you can easily flush the primary heat exchanger during maintenance.
Because manual press tools only go up to 1". I could have rented a real press tool, but it's hard to know how long I would have actually needed it. So sweat the 1 1/4" and press the rest.Pulse said:Why have you decided to do a mixture of sweat and press?
Thanks for all the sweat tips. I will abide.
1
