Heat loss calculation program room by room
plumb1pa
Member Posts: 10
The last post I saw was from 2004 so I'm asking this question again for today.
Mostly doing hydronic heating.
thanks in advance
thanks in advance
What is the question?0
If you are looking for a good program for manual J I use LoopCAD MJ8 edition and couldn't be happier with it. It costs a bit to get started, and you have to pay a yearly license renewal fee to continue getting updates. worth every penny to me, but I use it every day
https://www.avenir-online.com/AvenirWeb/Corporate/ACCAApproved.aspx0 -
Every hydronics pro, consultant, designer, troubleshooter, salesperson, etc should have Siggys Hydronic Design program.
The load calc is super simple to use and it allows you to build custom wall assemblies, vary basement depth, etc.
I think the demo allows you to do one calculation? Certainly worth 99 bucks.
https://www.hydronicpros.com/shop-onlineBob "hot rod" Rohr
I'm not seeing Heat Load Pro listed as an ACCA approved Manual J program. Might not mean much though. I've tried CoolCalc. I don't think it worked well.0
- 50 Industry Classes
