Replacement for old Honeywell S86H intermittent pilot control
garbid
Member Posts: 17
in Gas Heating
Can any of the "old hands" recommend a suitable replacement for my Honeywell S86H intermittent pilot with 100% shutoff and auto ignition (25v, PV & MV = 2A max., 90 sec. ignition trial)? Honeywell doesn't show a replacement in its cross reference guides and the sources I've checked list it as obsolete (with good reason: it's on a very old Burnham boiler that has worked flawlessly for decades). There's nothing wrong with it but I fear that its age, like mine, might cause it to act up in the depths of winter one of these days. (I am replacing the Aquastat as well for the same reason.) Thanks for you help.
Use the Honeywell S8610U. It can be programmed to mimic your present control.
Consulting1 -
Thanks for the suggestion, Steamhead.0
Steamhead: Does the Honeywell S8610U ‘s lower PV load rating of maximum 1A vs the old unit’s 2A make any difference?0
Shouldn't. What gas valve is on that unit? Is there a separate pilot valve?
Consulting0 -
The gas valve is Honeywell VR 844 P 5018 (also an old one but seems to operate fine).0
Hellow @garbid,
As @Steamhead said above.
I can't find a specification on that Gas valve. Someone could measure the PV current to be sure.garbid said:Steamhead: Does the Honeywell S8610U ‘s lower PV load rating of maximum 1A vs the old unit’s 2A make any difference?
Honeywell document.
https://s3.amazonaws.com/s3.supplyhouse.com/manuals/1299090484970/49449_PROD_FILE.pdf
S8610U replaces
S86H1006
S86H1022
S86H1048
S86H1089
S86H1097
S86H1105
S86H1121
S86H1147
One Pipe System0 -
Thanks for the information and link, 1095_A. I’ll measure the PV current as you suggested. I assume I do that from the existing pilot module to the gas control.0
Hello again and thanks for all of the tips. The Honeywell (Resideo) S8610U is indeed the correct replacement for my old Honeywell S86H1006 module and now I’m ready to install the new one, but I’m a bit confused as to where the old 25v(1) and 25v (2) wires connect on the new module as the installation instructions aren’t particularly clear. (There is no vent damper.). Thanks for clarification.0
Hello @garbid,
I suppose the only oddity here, is it to make sure the old 25v(1) or 25v (2) wires from the boiler (one or the other) were not grounded elsewhere. If so the grounded one should be connected to the 24V (GND) terminal.
One Pipe System0 -
Always read through your installation documents so you are familiar with the control wiring.
Thanks for your responses and helpful tips.0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
