Help Identifying Baseboard Brand
sethmcalister
Member Posts: 1
Hi,
I'm working with a client that has asked me to find replacement end caps for their hot water baseboard, unfortunately, there doesn't seem to be a brand stamped anywhere as far as I can tell.
Here are a few pictures:
Thanks in advance!
Thanks in advance!
Good luck....Slant Fin has closed its doors and I haven't been to happy dealing with Embassy who purchased them. Mad Dog 🐕0
I suspect the baseboard in the photos was manufactured about fifty years ago. I highly doubt you will be able to match it or get components any more.
Like others have suggested, you may forced to remove and replace it.0 -
Slant Fin ****, they are way to NARROW when working with older Systems! I am searching for end caps that are 3 1/2" deep x 7" tall right now & can't find anything deeper than 3". Even buying all New covers & back plates won't work, UNLESS you want to do a ton of re-piping because you cannot push the heating elements back close enough to the walls because of the pipes coming up thru the floor.0
- 50 Industry Classes
