Underfloor heating controls
mrridout
Member Posts: 7
I have scoured the internet for info on what controls are needed for a simple underfloor hydronic system. I do not want to individually control the temperature in each zone, but I do need something that my thermostat talks to to maintain the chosen temperature. Will the thermostat control flow volume, boiler water temperature, blending or what? I am assuming that the blended water temperature is chosen and remains static as does the flow rate. I could be wrong though. So what is the control device that is connectd to my thermostat and where is it in the manifold system? Mick
Most of those tasks are controlled by the boiler, at the boiler
The room thermostat sends a call for heat to the
boiler
one zone system?
what type of boiler?
drawing of the piping available?Bob "hot rod" Rohr
No specific piping arrangement yet. Four zones. Not really a boiler, but a tankless water heater. The lowest temperature available at the water heater is 100F and up to 120F. So you are telling me that the room temperature control has nothing to do with the manifold and its parts, but with the call for heat to the water heater? So basically I would have to have a control that turns that unit off and on. Mick0
Well a tankless water heater is different animal
it us nit designed or intended to be used for Hydronics. .So it may not have the relays electrical connection for thermostats, proper safeties, etc
It may have gave a minimum flow that a single zone found not meet?
I’d encourage you to go with a small boiler you get out door reset, and a lot of control functions that a system like that really needs
By the time you reverse engineer a tankless water heater to do the job of a boiler, you could have bought a boiler to do the job properly. The boiler will also perform better and last longer.mrridout said:No specific piping arrangement yet. Four zones. Not really a boiler, but a tankless water heater. The lowest temperature available at the water heater is 100F and up to 120F. So you are telling me that the room temperature control has nothing to do with the manifold and its parts, but with the call for heat to the water heater? So basically I would have to have a control that turns that unit off and on. Mick
Albert Einstein0 -
All of that, and, eliminate the potential for Legionella infecting the potable water.Zman said:No specific piping arrangement yet. Four zones. Not really a boiler, but a tankless water heater. The lowest temperature available at the water heater is 100F and up to 120F. So you are telling me that the room temperature control has nothing to do with the manifold and its parts, but with the call for heat to the water heater? So basically I would have to have a control that turns that unit off and on. Mick
By the time you reverse engineer a tankless water heater to do the job of a boiler, you could have bought a boiler to do the job properly. The boiler will also perform better and last longer.0 -
The tankless is dedicated to the heating system and nothing else. I have the tankless. How much would a boiler for a 1000 sq ft house cost?0
What is it that makes a boiler better. I really don't know anything about them. I'm in Texas and boilers are only used in big commercial and industrial concerns.0
Also, in Texas, boilers must be installed by a licensed boiler tech. It must be inspected regularly by state inspectors and meet rigorous specs. All this sounds like a pain and very costly. Just the boiler would cost more than my whole system. No, I think I will stick with the tankless water heater. Now does that put me outside the reach of any other advice anyone might have?0
The tankless is only on when it senses water flow. Could I stop and start the pump or is it preferable to have it running all the time?0
I could use a thermostat to turn on and off the tankless. I don't really see that this is reverse engineering.
There is radiant installed in Texas, where are you located?
I’d be surprised if the State boiler inspector does residential inspections. They are not usually staffed for that. But it is Texas😏
If you have a brand and model tankless in mind, call tech support and ask how to wire a heating thermostat, and how to pipe it. That way you won’t void any warranty.Bob "hot rod" Rohr
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
