One More Question About Our Old Guy Plumber
gotgas
gotgas Member Posts: 96
One more question. When he converted the top of the MPT washing machine box to pex, he did not use any tape. He only used pipe dope.
Also, we are running all Pex A and he used a Pex B barb connection and a crimp ring. Not the copper type, but the stainless crimp rings.
I don't want to insult the old duffer, but I really would like to replace those with PEX A to FPT connections with tape and use the proper expansion fitting. What do you think?
  • HomerJSmith
    HomerJSmith Member Posts: 2,779
    edited August 2023
    You mean Oetiker clamps? I have used these clamps on Type A pipe and haven't had a problem. Pipe dope is fine. Tape is fine. Tape and pipe dope for the belt and suspenders guys is fine.
    A problem might be that the type B barbed brass fitting may be smaller than a type A fitting which relies upon a expanded Type A pipe to provide full flow. For a washing machine it would make much difference regarding flow.
    gotgas
  • WMno57
    WMno57 Member Posts: 1,408
    On new construction with pex for water, wouldn't it be possible to completely avoid pipe threads and buy fixtures that can be directly crimped to pex? That way you only need to buy one labor skill set. Crimping.
    Tape vs dope vs tape-dope combo. Any of those three methods can be done correctly or incorrectly. If you insist on adding tape, you are micro-managing your plumber.
    gotgasMad Dog_2
  • HomerJSmith
    WMno57, ya, I get enough micro-managing from my wife. I surely don't need it on the job.
    gotgasRobomooIntplm.Mad Dog_2
    mattmia2 Member Posts: 16,854
    edited August 2023
    Some plastics don't like you to use dope on them because they are concerned about damage from the petroleum products in the dope. It is very unlikely to cause a problem even if they prohibit it in the instructions. I think you can use pex b fittings on pex a. Not as good a joint as expansion fittings, but unless you specified it, I think it is allowed by the code and the manufacturer.
    gotgasMad Dog_2GGross
    hot_rod Member Posts: 27,489
    As long as the listing numbers are correct you can mix and match tube and fittings. Pex A can be expanded or crimped.
    If you are talking just a few fittings the difference between a crimp and expanded fitting will not be noticeable at the wash machine.
    gotgas
  • gotgas
    Appreciate it. I am going to leave it alone.
    Mad Dog_2
  • John Abbott
    John Abbott Member Posts: 361
    hot rod hit the nail right on the head, the clamping method msut be listed for for the fitting, very specific numbers.
    gotgas
  • gotgas
    edited October 2023
    Here is the follow up.
    I left the fittings alone. We connected and pressurized the water system and they both leaked. We could not turn on the water at the street until after the drywall was installed, finished, and primed. (Due to some really stupid city issues) Now we have to cut primed drywall to get to the box to correct the terminations. A real bummer.
    109A_5 Member Posts: 4,062
    Hello @gotgas,
    Was it pressure tested with air before the drywall went up ?
  • gotgas
    109A_5 said:
    Hello @gotgas,
    No, he did not think that was necessary because the town did not require it.
    Mad Dog_2mattmia2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,552
    How many leaks?  Mad Dog 🐕
    edited October 2023
    Hello @gotgas,
    gotgas said:
    109A_5 said:
    Hello @gotgas,
    So he is good with repairing the leaks and the damage and extra work and materials needed they caused ???
    Mad Dog_2
  • Mad Dog_2
    edited October 2023
    Sorry guys...don't like Lawn Sprinkler clamps (Oetiker?). Uponor or Viega.  Its no excuse, but I prefer to use products that don't come back to haunt me.  Mad Dog 🐕
    realliveplumberreggi
    edited October 2023
    Now the plumber can pay for the drywall, painting, and other finish work. Unless your local code takes a major detour from the model codes, a pressure test with water is required. That should be performed before it is connected to the utility.(and before the walls are closed up if the plumber doesn't want to be on the hook for reworking that).
  • gotgas
    Only two, the two connections this thread referenced in the first post. The only connections he made were the two on the washing machine box. We did the rest ourselves. His were the only ones that leaked.
  • gotgas
    He used oetiker. Everything else is expansion. Now those are expansion as well. No oetiker in either house.
  • gotgas
    edited October 2023
    I think we will let it slide. He charged us a total of about $2,500 to completely Plumb two houses. We did most of the water supply lines ourselves, under his oversight. He did all of the drain lines himself including the ones under the slab. All of the drains and vents were tested.
    Because we used vaulted ceilings, some of the vent lines were really tough to locate. He did a great job on all of that and is also 80 years old.
    As disappointed as I am about these leaks, overall we are thrilled with him. I am not even going to tell him about these leaks. He is a pretty good old guy.
    realliveplumberSuperTechhot_rod
