Suntec pump leak or return line leak ...
seized123
Member Posts: 485
So on a (future) one-pipe system with Tigerloop and anti-siphon valve:
1) With the Tigerloop, I infer that the anti-siphon valve would not detect a leak in the short return line between pump and Tigerloop, as the anti-siphon closes when it senses loss of vacuum, and it seems to me that with such a leak the pump can keep on applying vacuum to the supply line while happily spilling oil from the return. In case of such a return line leak, especially a larger one, is that what would happen? Would the leak want to leak at pump capacity (unlike a purely one-line system with much lower gph)? Are there any measures that can be taken to mitigate such a leak there? It seems to me that, when this new system is installed, this small return line to TL will be the weakest link consequences-of-leak-wise. If I could do without the Tigerloop I would, since the anti-siphon would then detect any leak from tank to burner (the valve I'm getting goes at the aboveground tank top), but the valve manufacturer requires a de-aerator and I don't want to void the warranty.
2) I've heard about blown pump seals (or "blown pumps"), I don't really know what it means; will there then necessarily be loss of vacuum, so the anti-siphon valve will close (again, assuming the existence of a return line to the TL)? And in general if the seal goes, will I necessarily see a leak, or can bad things just happen internally, and what would those bad things be? What can cause the seal/ pump to "blow" or otherwise destruct?
Nutty questions maybe, but I'm trying to learn as much about this stuff as I can - it's endless, I see why it takes decades to get really good at all this.
Thanks in advance.
Thanks in advance.
Doesn't sound like a likely event. Would the leak become obvious on the outside?0
Whoa. That wouldn’t be good. Would that oil get schpritzed from the squirrel cage past the nozzle into the chamber, causing havoc? What might you notice wrong?0
Yup. Quite a mess. A major oil leak.seized123 said:Whoa. That wouldn’t be good. Would that oil get schpritzed from the squirrel cage past the nozzle into the chamber, causing havoc? What might you notice wrong?
Consulting0 -
Is that something one should check for periodically, say by flipping up the transformer and looking inside? Or would there be other noticeable symptoms?0
I think I want a heat pump… (Just kidding, maybe.)0
@seized123, please don't get a heat pump. If for the only reason you asked 300 questions about oil lines.
I don't think we can do it again with heat pumps, thermostats, air flow etc...
But to answer your questions:
1. Yes That's a main reason why 2 pipe is never recommended by most, and Tiger Poops are never recommended unless absolutely needed, which is almost never. Oil dearators and their crap hoses have an expiration date and manufacturer's recommended replacement date. If oil leaks after that date from their components, it's not on them. Which is why if I have to use a oil deaerator, I started hard piping them. Although a manufacturer's rep on FB started selling a newer style red flex hose that seems to look promising.
2. Easiest and quickest way to blow a pump seal is to have a return line closed or restricted-another reason to avoid 2 pipe and Tiger Poops. Oh and high input pressure.
Other than that, they rarely just blow, and they rarely fail. Don't even think I replaced one last season.
How often should you check it...never. How often should your oil burner tech check it...annually.
If you don't smell nothing, don't hear nothing, and don't see nothing when you walk by the burner, there's nothing to fix, but you can make it worse constantly touching it.There was an error rendering this rich post.
@STEVEusaPA I have not asked 300 questions, I have asked 423.5, and if you want me to drive you even more nuts see the latest post on the old 2 to 1 pipe thread, complete with diagram.1
What was the .5?
It's when I asked "What should I do if ..." and then I guess I fell off my chair or smelled dinner burning. If you have time, check out the diagram in the 2 to 1 line post, I'm interested in your opinion.
I think I'll try some DIY rocket science, it has to be simpler than oil heating and HVAC.0
