New boiler with domestic hot water - Burnham Alta or WM GV-90 with indirect HW heater
I need to replace my 30 year old hydronic boiler with indirect HW heater soon. Will do a Manual J. Will the hot water output on the Burnham Alta be satisfactory for shower or bath? There is a big cost savings by not needing an indirect hot water heater. Baseboard was probably designed for 180* water. Living in Denver. If it was your house, what would you install? Natural gas fuel.
Thanks for your insights.
Steve
Steve from Denver, CO
    mattmia2 Member Posts: 16,693
    I'd start with the heat loss and radiation survey to figure out if you can run low enough water temp to run a condensing boiler at condensing temps.
    If you cant then the next question is do you have a conventional vent that is in good shape.
    If you have a good vent and cant run return water temps below 140 or do then there is no benefit to a condensing boiler and a conventional cast iron boiler makes more sense.
    There are limitations to a combi, how you use hot water and your incoming water temp makes all the difference in if that makes sense or not.
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    No chimney. Present boiler is direct vented through the wall. I am doing the Manual J and will calculate the present baseboard BTU output. Since Denver has lots of sun, daytime requires a lot less energy for heating. Incoming water temp in winter could be 45-50 or so.
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Are you retiring your WM GV-5?
    How old is it and did it start to leak?
  • Steve Garson_2
    The present boiler is fine, but 30 years old and a GV series 1.  I’m thinking it might be prudent to replace sooner rather than later.
  • JUGHNE
    There is another posting here about the WM GV 90.
    30 year cast iron and still running, I have followed your postings for the old boiler, and you seemed to minimal issues with the GV.
    I would lean in that direction again, IIWM.
    What do you have for WH now?
  • Steve Garson_2
    Amtrol indirect tank
