Boilers NTI FTVN150C Vs Burnham Alta 95% Combi gas boiler
jrlang63
jrlang63 Member Posts: 5
Having new gas boiler installed. Comparing quotes and boiler models, have no experience or knowledge of NTI boilers. My existing oil burning boiler is 25+ year old Burnham V-13A-T. New proposed gas boilers are NTI FTVN150C gas modulating boiler or Burnham Alta 95% 180k BTU modulating Combi. I just want to know if NTI is a good product because I never heard of them. I am favoring the Burnham model because that is what I already have heating my house. But, I would like to know more about NTI boiler and its reputation I know its a Canadian company establish in 1969. Any feedback would be helpful
  • GGross
    GGross Member Posts: 1,733
    They are going to be extremely similar, the heat exchangers are most likely made in the same factory. They are both well known brand names. I would suggest you pick this one primarily on who you think would be a better installer, and warranty terms. Ask the installers how close local parts are stocked, and if the distributor actually stocks parts.
    GroundUp
  • GroundUp
    GroundUp Member Posts: 2,465
    NTI is a good product and has a much better track record with high efficiency boilers than Burnham, but this Alta has gotten with the times as it's only been out for a couple years. As GGross said, very comparable units and I too would recommend whichever installer you feel will better support the product.
  • jrlang63
    Thank you for the feedback
