Which 2 or variable speed Heat Pump condensers can use old 2-wire connection to the air handler?
rsilvers
Member Posts: 182
Which 2 or variable speed condensers can use old 2-wire connection to the air handler?
I heard that Trane has such a unit. It is hard to pull new wire to this location. Need the system to be a heat-pump to qualify for the large rebate.
Excellent tip. I should have thought of that as I installed two of their units for thermostats before.
I may want a variable speed inverter condenser though - and I think that means a communicating system with data. So far, only Trane seems to do that with two wires.
For distributors I use FWWebb or SupplyHouse, and neither does Trane, so looking for other options. Or I could just get a two-speed and use Fast-Stat.0 -
This is a full inverter that goes down to 25% power and is non-communicating, which probably means it can somehow work with the Fast-Stat. It is the weekend or else I would be calling them.
https://www.morleyassociates.com/wp-content/uploads/2021/03/02-EODA18H-4860-Submittal-20191015-1.pdf0 -
Goodman makes a 2-wire communicating full inverter, so that is an option.
Daikin SkyAire or VRV4s uses 2 wire communication. It's available with a vertical airhandler.
http://daikinac.com/content/light-commercial/skyair/skyair-system-heat-pump/
The Goodman system I installed in my own house has the option for a 2 wire communicating setup but I've never used it.
The only reason I didn't use it was I didn't want to have to use their re-badged thermostat. I don't remember who made it, but I didn't want to be locked into only using that one. So, overall a very minor, maybe even silly reason.
- 123 Chimneys & Flues
