Boiler Identification
Amorgian1975
Amorgian1975 Member Posts: 1
edited July 2023 in Gas Heating
Good Evening Gentlemen, I looking to identify the model of the boiler and circa in the photos below.
The doors have the logo of Brittania, however I can not find any similar model.
It is located in the basement of our Church’s Centre.
  • bburd
    bburd Member Posts: 1,173
    edited July 2023
    You are located in the UK, right? Most of us on The Wall are in North America. Brittania is not a known brand name here, and I have never seen a boiler quite like those. They are almost certainly from before World War II, or perhaps just afterwards. Those burners may or may not be original to the boilers, they may have been converted from solid fuel. They look like oil burners, though you have posted this under "gas heating". Is there any sign of a coal bin nearby?
    What heats the building now?
    Bburd
    HVACNUT Member Posts: 6,880
    They're gas burners.
    Can you get behind them? Maybe there's a tag on the back.
    Or remove the jacket and see if the block is stamped.
    The electrical looks like it needs tidying up a bit.
    Amorgian1975
  • JUGHNE
    JUGHNE Member Posts: 11,471
    The floor looks as if the place has been flooded.
    Controls that got wet should be replaced, especially if gas.
    Is there actually any piping connected to this?
    Amorgian1975
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,643
  • unclejohn
    unclejohn Member Posts: 1,833
    From the looks of that boiler it should be obvious to anyone that prayers work.
    Mad Dog_2
  • Aidan (UK)
    Aidan (UK) Member Posts: 290
    I was about to say that they looked like Ideal Standard sectional cast iron boilers, but someone got there long before me.
    I used to see those in school buildings in London in the early '80s, originally coal fired, converted to oil and/or converted to gas. I think I've long since binned any information I had about them.
    They're not condensing and are inefficient, compared to modern boilers. The gaskets will contain asbestos.
    GGrossMad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,274
    Hiya Aidan!  You must have seen some wild stuff over there in London Town!  Your city got hit so hard by The Blitzkrieg in the Battle for Britain 🇬🇧.  I'm sure some buildings were leveled (New heating systems post WW II), the ones down the block untouched (Pre WWII).  Are there many like this one left?  Any Steam Heat whatsoever?  Tally Ho! Mad Dog 🐕
    Amorgian1975
  • flowpro
    flowpro Member Posts: 5
    Well I don't see any computer controls or PVC vent pipe so all I can tell you is that as long as they are not leaking water on the floor then they are good reliable boilers!
    Climate change is a hoax!
    Boycott all companies and their technologies that support the hoax!
    jimna01MikeL_2
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,360
    @flowpro, please follow forum rules and refrain from posting your political opinions. We're not here to debate climate change.
    President
    HeatingHelp.com
