Beckett burner blower wheel size
maxmax
maxmax Member Posts: 1
I have a Beckett burner on my pressure washer . I need to replace the blower wheel  how do I measure so to order correct one .
Please help. There is no label on this burner.
    HVACNUT Member Posts: 7,426
    Post some pics of the burner and the fan. If it's old, my guess is a 1725 SR
  • STEVEusaPA
    Why do you need to replace the blower wheel? And are you sure that’s all you need to replace?
    EdTheHeaterMan Member Posts: 12,132
    edited July 2023
    You should be able to put the burner model number in this website and get the OEM part number you need to order. https://www.beckettcorp.com/support/find-a-part/
    If you can post a picture of the burner, we can usually tell what burner it is without the label.
    With a picture and the following dimensions someone will be able to tell you the part number
