Beckett burner blower wheel size
maxmax
I have a Beckett burner on my pressure washer . I need to replace the blower wheel how do I measure so to order correct one .
Please help. There is no label on this burner.
Post some pics of the burner and the fan. If it's old, my guess is a 1725 SR0
Why do you need to replace the blower wheel? And are you sure that’s all you need to replace?
You should be able to put the burner model number in this website and get the OEM part number you need to order. https://www.beckettcorp.com/support/find-a-part/
If you can post a picture of the burner, we can usually tell what burner it is without the label.
With a picture and the following dimensions someone will be able to tell you the part number
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
