Hot water is suddenly hotter than usual- boiler
hockeyman70s
hockeyman70s Member Posts: 18
Hey all, this place is the best. I have an ancient (probably 40s boiler) that keeps on going. The last couple of days the faucets and shower in the house have been running noticeably hotter than usual. Wondering what may cause this? Thanks!
    Jamie Hall Member Posts: 27,036
    Two possibilities: the aquastat is not functioning properly or if there is a mixing valve, it's stuck.
    hockeyman70s
    EdTheHeaterMan Member Posts: 11,782
    Are you still using this dinosaur to make your hot water?
    I can't see the mixing valve in this photo so My guess is the Aquastat is calling for hotter water for some reason. Could be it is defective, or it could be an adjustment that was changed accidentally. I would guess the control on the water heater (Blue) is the reason, but without actually knowing how your mixture of mismatched parts is wired up it may also be from the other 2 controls (Yellow, Green) that have themperature adjustments therein.
    mattmia2 Member Posts: 16,080
    If the boiler is warm start it could be a check valve is stuck open allowing gravity circulation too.
