Hot water is suddenly hotter than usual- boiler
hockeyman70s
Member Posts: 18
Hey all, this place is the best. I have an ancient (probably 40s boiler) that keeps on going. The last couple of days the faucets and shower in the house have been running noticeably hotter than usual. Wondering what may cause this? Thanks!
Are you still using this dinosaur to make your hot water?
I can't see the mixing valve in this photo so My guess is the Aquastat is calling for hotter water for some reason. Could be it is defective, or it could be an adjustment that was changed accidentally. I would guess the control on the water heater (Blue) is the reason, but without actually knowing how your mixture of mismatched parts is wired up it may also be from the other 2 controls (Yellow, Green) that have themperature adjustments therein.
- 50 Industry Classes
