Can anyone help me ID the age of this boiler & how to clean it?
emaydeoh
emaydeoh Member Posts: 57
2 pipe hot water radiator system. Curious if the age and how to maintain it! Does it need a yearly clean out? I’m coming from a steam system which I knew more about.
    HVACNUT Member Posts: 6,756
    edited June 2023
    Not a yearly "clean out", but an annual maintenance. A tech would check all the safeties and limits. Check lockup and manifold gas pressures. Remove and brush the burners. Check the orifices. Tighten all electrical connections. Test the thermocouple. You have 1 thermocouple and it looks like 2 pilot assemblies sitting on top of the boiler. Cycle heat zones. And of course combustion and draft tests.
    Just saw the 303 area code. You might have special requirements for gas (orifice size) and water pressures, and combustion air if you're considered high altitude.
    emaydeoh
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,143
    Looks like a Slant Fin late 1990s??  Mad dog 🐕
  • random12345
    random12345 Member Posts: 503
    Check all around the boiler for a plate. Should have the manufacturer name and model number. Looks like a Super Hot Saturn Series made by Allied Engineering: https://alliedboilers.com/products/saturn-series-boiler/. Check the "Literature" tab for the instruction manual.
    HomerJSmith
  • emaydeoh
    @HVACNUT so helpful thanks! How do I test the thermocouple?
    may need to hire someone for everything else!
  • gyrfalcon
    gyrfalcon Member Posts: 187
    Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.
  • Derheatmeister
    Derheatmeister Member Posts: 1,651
    Last fall we replaced one just like this up in the high country (Summit)
    Probably reduced the AFC by 30% to 40%.
    Not a big fan of pumping into the return (Factory setup for ease of shipping ?)
    This one also has the manual bypass setup :(
  • emaydeoh
    @Derheatmeister what does AFC mean?
    Do you know if this is an old/bad boiler? The website seems to show its from 2013 (?) but I can’t tell.
  • emaydeoh
    @Derheatmeister also what is the manual bypass setup? Thanks!
