Is there a thermostat or control that will use one heating system vs a second based on time of day
Steve Garson_2
Member Posts: 712
I have natural gas baseboard heat as well as split system heat pump. Has anyone created a control that will use the boiler during a set period, say 11AM to 7PM when electric rates are high, and the heat pump from 7PM to 11AM when electricity is less expensive?
Steve from Denver, CO
Where is gas cheaper than a heat pump!0
Would the water heater type time clock switch between the boiler and the air handler?
Any time clock with a single pole double throw switch function might work, it would be in the basement.
Use just the same tstat that calls for heat now.0 -
I think the timer with a 3 pole relay would work. I have dummied up a drawing with a typical heat pump and a typical boiler. When the timer is on the Electric system, All the wires are connected to the HP low voltage system. When the timer is on the gas system, the Compressor, Fan, and Electric heat are disabled by the relay and the other contact in the timer engages the gas heat on the same thermostat.
You could also use two thermostats. It would be simpler and you could get a different temperature based on the timer setting. (if that happens to line up with the electric rate change timing)
I'm not exactly sure how the heat pump might operate with a RIB Relay only on a setback thermostat Bob. when the setback happens, you operate all the system controls at a different temperature. The RIB will only be energized or de-energized based on the call from the thermostat. It will not actually operate the other appliance at the set point temperature.hot_rod said:just a double throw 24V RIB on any programable stat. The program toggles the relay to chose either or heat source.
- 50 Industry Classes
